Removing front signals
Old Jun 28, 2005 | 02:19 AM
600RRJOE's Avatar
Default Removing front signals
How do I remove the front signal stalks on my 05 600rr? Im guessing i take off the front airscoops to gain access to that area?
Old Jun 28, 2005 | 03:09 AM
c45's Avatar
c45
Default RE: Removing front signals
you can go from the top. take the side fairing off and the little top piece and its easier. thats how i did mine
Old Jun 28, 2005 | 09:55 AM
RiPTOR's Avatar
ORIGINAL: c45
yup... same here. It's gonna be a little tedious and aggravating but you'll get it.
Old Jun 28, 2005 | 01:18 PM
600RRJOE's Avatar
thanks for the info....one more thing how are the signals attached? with a nut?
Old Jun 28, 2005 | 03:39 PM
RiPTOR's Avatar
I'm trying to recall how the stock signals were installed, it's been a while now since i've changed them out. If i remember correctly there are basically self tapping screws into the frame. I believe once you remove those the signals will kind of hang there. That's when you need to get behind the fairings and do the new wiring.
Old Jun 28, 2005 | 07:43 PM
c45's Avatar
c45
on the 05 its a nut holding them on if i remember correctly. i think it was a 10mm nut. when you get them off there are going to be two holes one was for the wires and the other was the bolt. if you go with the flush mount leds you will need to drill new holes. it hurts to drill the fairing but its worth it in the end.
jmlathrop
Jul 31, 2008 10:31 PM
sk8rat
Jun 26, 2008 05:41 PM
hill1513
Jan 26, 2007 01:16 AM
birde
May 24, 2006 01:14 PM
sushix2
Mar 15, 2006 01:32 AM
