removing front rim without a front stand
Old Mar 14, 2006 | 02:44 AM
sushix2's Avatar
Default removing front rim without a front stand
I was wondering if theres anyway to lift up the front of the the bike without a front stand. I need to change the brake rotors.
Are there any points on the bike strong enough so that I can use a jack stand to prop the bike on the rear tire and kick stand?
Old Mar 14, 2006 | 10:51 PM
brian97's Avatar
Default RE: removing front rim without a front stand
I have removed the front wheel by using 2 motorcycle tie downs and a couple of hooks from my garage ceiling. put a soft strap on each clip-on and pull the tie downs one at a time to raise the front wheel. As for the rear, remove the slip-on and use a jackstand under each rear set.
Old Mar 15, 2006 | 01:32 AM
transamlt1man's Avatar
I agree lifting it will work. I have also takin the front wheel off with a floor jack. I put it on the side stand and turned the bar I think all the way to the right. Put the floor jack under one of the forks. Anyways I cant remember how but I got it to work safely. lol
sk8rat
Jun 26, 2008 05:41 PM
bluej511
Jan 11, 2008 11:03 PM
fstR1
Oct 13, 2006 01:01 PM
