No power, ICM?
Old Nov 3, 2006 | 07:23 PM
Destinmatt's Avatar
Default No power, ICM?
My bike was running just fine, and then I turned it off for 2 minutes and I didn't get any power. If I disconnect the battery and reconnect it I get power to everything until I hit the ignition switch and then everything goes dead. I took the Ignition control module off, and the power also comes back and the starter will turn over. Does this pretty much mean the ICM is bad or is there anything else I should check? Anyway to check the ICM?
Old Nov 6, 2006 | 01:10 PM
Hoosier1104's Avatar
Default RE: No power, ICM?
Check your voltage regulator with a multimeter.
Old Nov 16, 2006 | 11:14 PM
Destinmatt's Avatar
It was the ICM.
Old Feb 26, 2007 | 07:56 PM
keithacole's Avatar
sorry,, newb..
ICM=?
i think i may have the same issue..
Old Feb 26, 2007 | 10:22 PM
bindelsf2's Avatar
ignition control module or CDI box--->
[IMG]local://upfiles/7261/1FA5E72595BE48168EC6CAF86E2D4E60.jpg[/IMG]
Old Feb 26, 2007 | 10:25 PM
CBRider93's Avatar
its the ignition control module. its the black box located on the right side of the tail. right next to the voltage regulator
Old Feb 27, 2007 | 02:47 AM
pontiacat's Avatar
voltage regulator
http://cgi.ebay.com/ebaymotors/GUARA...spagenameZWDVW
coolbluedab
Feb 7, 2014 07:13 PM
romanboy
Jan 19, 2013 12:53 AM
__Z__
Jul 14, 2010 10:00 AM
Karmakazi
Sep 29, 2009 09:58 AM
Certified Ryder
Nov 12, 2007 10:13 PM
