Removing front fender?
Old Dec 18, 2006 | 02:43 PM
keasy's Avatar
Default Removing front fender?
Do I need to remove the front wheel to remove the fender? I loosened the bolts on the fender but it wouldn't budge.
Old Dec 18, 2006 | 09:07 PM
AlpineCBR600's Avatar
Default RE: Removing front fender?
watch out for the small plastic clips that connect the front too the side fenders... you dont wanna break them. .
Old Dec 18, 2006 | 09:44 PM
gobtool's Avatar
I've got an F3 and I'm not sure if the fender is attached the same or not. On mine I had to take an allen wrench and take out one screw on each side, then take a socket (I think 8mm) and take out two more screws. The two other screws also held on a bracket for the brake lines. Then the fender just lifted off. Hope that helps.
cyber00677
Jun 27, 2008 11:53 PM
hksicivicsi
Sep 23, 2006 06:26 PM
sushix2
Mar 15, 2006 01:32 AM
