Fuel issue
Old Dec 12, 2021 | 01:56 PM
Sparky46's Avatar
Ok came home put another couple of litres in and left the tank open, good charge on battery now , could see the fuel being sucked down, fired up after a bit of adjustments with the choke running sweet now thanks
Old Dec 12, 2021 | 02:28 PM
Very sweet. It sounds like your vacuum line is pinched or blocked.
Old Dec 12, 2021 | 04:41 PM
Phil314's Avatar
Sounds like you have it running now.
But just an FYI, F2's are gravity feed and should not have a filter after the petcock.
The fuel line should connect directly to the carbs.
The restriction of the filter can cause problems, especially at full throttle and such.
Old Dec 13, 2021 | 03:15 AM
Sparky46's Avatar
The Petcock does have a filter attached inside. Do you recommend I remove the inline filter then? It’s running lovely but I’ve not had it above 6k yet won’t be getting road tested probably until early next year.
Old Dec 13, 2021 | 06:06 AM
As it is running well for now I would leave it, but bear in mind Phil314's comments in case it starts to struggle higher up the rev range.
Old Dec 13, 2021 | 07:34 AM
Phil314's Avatar
I ride a lot of miles and value a reliable bike that just works and never gives me a problem.
If it was me. I'd remove it. Gravity feed should never have a filter before the carbs.
I've seen more than a few people do this and it causes problems.
And it just isn't needed. It's not improving or helping in any way.
The filter in the tank above the petcock is all you need.
Old Dec 13, 2021 | 08:24 AM
Sparky46's Avatar
Fair enough thanks. I too just want a bike to work
Old Dec 13, 2021 | 09:29 AM
Phil314's Avatar
I'll amend this statement slightly for knowledge sake.
Some gravity feed systems can use a small sintered bronze filter.
They offer zero restriction compared to paper filters and will work.
like this:
www.amazon.com/K-N-81-0221-Fuel-Filter/dp/B000E2AR70 www.amazon.com/K-N-81-0221-Fuel-Filter/dp/B000E2AR70
But in the case of the F2, still not needed, as it would be redundant to the filter already in the tank.
IAGator
Apr 23, 2018 10:50 AM
Bigtex85
Jul 14, 2017 09:43 AM
williamsergio
Mar 19, 2009 09:54 AM
89cane
Nov 8, 2007 07:18 PM
