no fuel to carbs
Old Nov 7, 2007 | 01:25 AM
89cane's Avatar
Default no fuel to carbs
i just bought a hurricane and cleaned the carbs cut i cant seem to get fuel to flow from the tank to the carbs. any input would be appreciated. well i look forward to starting to ride i might not get much time this season but i can get it fixed for summer. i have checked that the fuel pump and relay work the carbs just dont seem to take the fuel.
thanks i have refered to this website for many questions i have had.
Old Nov 7, 2007 | 01:44 AM
bergs's Avatar
Default RE: no fuel to carbs
Is the fuel shut-off on the the tank still turned off? I imagine you had to close the valve to keep the fuel from spilling out of the bottom....which leads me to my next question-->
Is there fuel in the tank?
Old Nov 7, 2007 | 08:29 AM
89cane's Avatar
there is fuel in the tank and i turned the petcock on just cant get the fuel into the float bowls.
Old Nov 7, 2007 | 09:01 AM
Gogar's Avatar
First, unhook the tank and just hold the tank up in the air and turn the gas on. Does gas come out? Good. Just in case, UP is on, MIDDLE, is off, DOWN is res.
If not, maybe a new petcock or take the petcock off and see if the filter in there is all jacked. IF it is, you -can- take it off but you won't have "reserve" any more, just ON up or down. Then see if that helps gas come out. Good. Hook it back up to the fuel filter.
Can you see gas sloshing around in the fuel filter? Undo the line -after- the fuel filter and pull the fuel filter off the nub, if it's not already. Hold it up in the air and turn the gas on. Does gas come out? Good.
If not, get a new fuel filter.
Try coming out of the tank into the filter, out of the filter straight to the carbs, and bypass your fuel pump. You might need to go get some 3/8" fuel line at the autopoarts store.
You need to get the tank up higher than the carbs, too. I know you know all this, I'm just making sure.
If that works, maybe it's something with your fuel pump. REMEMBER, that if it's the stock pump, the lines go - - IN = the fitting closest to the INSIDE of the bike, farthest away from you. OUT= on the outside, closest to you. Sometimes if the fittings are hooked up backwards it won't work either.
If the fuel pump is working you can put your hand on it and feel it go thump thump thump when you crank the starter.
Hope some of that helps out.
Old Nov 7, 2007 | 08:47 PM
89cane's Avatar
i tried to turn the petcock up and it puts out a little fuel then stops. but when i turn it down it turns on and keeps going i am gonna look at the petcock again right now. i might have to put more fuel in the tank that might be part of the problem may i ask how the reserve tank work?
thanks
Old Nov 7, 2007 | 09:46 PM
89cane's Avatar
thanks Gogar i think all i need is some new fuel and my bike should start this is my first bike so i never did any of this before. thanks again all new imput would be accepted i will let you know when i gte it started.
thanks again
Old Nov 8, 2007 | 01:20 AM
Gogar's Avatar
If you take the petcock out there's a little plastic filter that goes over it thats really long. It gets cut in half by a rubber washer in the middle of the filter. When you turn the petcock UP (full CCW) it's "ON, which uses the gas through the top of the petcock and the top of the filter. when the gas gets down to the level of that rubber washer, it will stop going through the top of the petcock and you have to turn to RES, (Down, or full ClockWise) which uses the gas in the bottom of the tank. That little plastic filter can get messed up pretty easy. When I got my bike it was trash, and my petcock was bad too.
But when you have a problem, just start at the easiest place and work your way down, like my other post. Sometimes it's easy and you can do something on the cheap before you buy parts you don't need.
Old Nov 8, 2007 | 07:18 PM
89cane's Avatar
ok thanks i agree with that last idea i dont have very much money to spend on the part anyway
617rider
Apr 26, 2014 07:06 AM
fiddy_nutz
Jun 23, 2011 08:03 PM
starturbo
May 16, 2011 01:19 AM
wooferdog
Jan 12, 2011 05:00 AM
iluvdalaydees
Jul 27, 2006 11:00 AM
