Cold running
Old Feb 12, 2010 | 04:32 PM
darthboost's Avatar
Default Cold running
Hey guys when I start my bike up and take off down the road it cuts out and sputters power like it's out of tune or sumthing at least untell it warms up that is. Any ideas on what that could be? Thanks
Old Feb 12, 2010 | 05:11 PM
tigertim20's Avatar
yeah, its COLD!!!
contrary to poular beleif, engines are not made to be turned on and used straight away, neither cars nor bikes are.
the reason for this is simple, there are a number of different metals used in your engine's construction, the crank, bearing cases, pistons, conrods, rings etc etc. all these different metals expand at a different rate, untill the engines reaches its normal operating temperature.
it is a fact that 80-90 % of engine wear occurs in the first 7 minutes of running, ie, when it is getting up to temperature.
this is why a bike that has 50,000 miles that is used only on long weekend rides (hot running) is normally in much better internal condition that an engine that has done 20,000miles, used only for the ten minute trip each way to work -(cold running)
solution, start your bike, with a bit of choke, let it run. THEN go out your pants, boots, jacket helmet and gloves on. by the time youve done this and come back out (a couple of minutes, say 3-8 minutes) the bike is warm., flick the choke off, and go crazy.
simple answer, let it warm up BEFORE you ride it.
Old Feb 12, 2010 | 06:02 PM
fireWire's Avatar
what tiger said, also don't forget to use minimal amount of choke as well.
high choke = high revs = high rev bad for cold engine.
Old Feb 13, 2010 | 02:37 AM
darthboost's Avatar
Okay I just never thought it would run as crapy as it dose I mean yea all motors run better warm and a little sputter here and there yea but it jerks and pops a fue backfires the whole 9 yards, but I guess your right I'll just let it run for about 5-10min befor I go out next time, the other day it was about the same temp out all day and night and it didn't act up as bad as it did today.
Old Feb 13, 2010 | 08:15 PM
halffast1g's Avatar
my bike runs like complete AZZHOLE if its not in the operating temperature. It's especially bad on these old carb'ed bikes
Old Feb 13, 2010 | 08:18 PM
CBRfenatic93's Avatar
+1
600F4inoober
Oct 12, 2010 11:28 AM
transambird_2000
Nov 24, 2008 08:53 AM
meeson01
Oct 4, 2008 06:04 PM
ampfp
Apr 7, 2008 02:22 PM
midnightF3
Sep 26, 2006 06:43 PM
