battery ?
Old May 21, 2006 | 08:44 PM
bubba_d_duck's Avatar
Default battery ?
it seams that my battery has to be charged about once a month. and if i do a lot of running around in one day my battery gets so weak it wont start and i have to jump it or pop the clutch. and its also a new battery
Old May 21, 2006 | 09:59 PM
Krokus_92F2's Avatar
Default RE: battery ?
Your charging system is bad. Voltage Regulators/Rectifiers are known problems on F2's. It is easy enough to run a diagnostic using a simple voltage meter. Your electrical system runs off your battery, so it is something you want to repair ASAP, unlike cars that run off the alternator. Voltage Regulator will run about $115.00 if you need one. Stock Honda Part is closer to $200.00.
Eventually you will ruin your battery if you don't repair your charging system, that will add another $50.00 or so to your repair bill.
Old May 23, 2006 | 09:50 PM
do you think a 1997 Honda CBR 600 F3 Voltage Regulator would work on my 92 cbr 600 f2?
Old May 24, 2006 | 01:25 AM
ORIGINAL: bubba_d_duck
I believe the F2 and F3 share the same Voltage Regulator. My parts book shows the same part number from 91-97.
But to be safe, you might ask a Honda Parts guy.
estate4life
Dec 4, 2012 11:08 PM
jharbinson
Dec 31, 2009 09:23 AM
xander071584
Dec 24, 2008 01:45 PM
njdjh2o
Apr 11, 2008 07:20 PM
MDZ600F4i
Oct 18, 2006 07:50 PM
