will using my car battery charger in my bokes battery hurt it?
Old Dec 28, 2009 | 12:25 PM
jharbinson's Avatar
Default will using my car battery charger in my bokes battery hurt it?
My battery is dead and I have a old charger for car batteries. can I use it to charger my bikes battery or am I going to blow it up? And do I need to take the battery out to charge it or do you just connect the charger while everything is hooked up?
Old Dec 28, 2009 | 12:33 PM
MC_spirited's Avatar
I would unhook the battery before using it, just in case. Make sure the charger is set at a 12 volt setting. I have used car charger on my bikes before.
A battery tender is never a waste of money. I always pull my battery out for the winter and a battery should never be set directly on concrete. I put mine on a piece of wood whenever it gets pulled out. I hook the tender up to my battery once a week In the winter if I remember.
Old Dec 28, 2009 | 03:45 PM
jharbinson's Avatar
Thanks for the info... I also meant to ask if my jumper box will damage the bike. Its just one of those boxes that holds a charge that youu plug up to your battery like jumper cables and starts it up.
Old Dec 28, 2009 | 07:17 PM
It probablly won't as long as it is hooked up properly but ya never know. Takes 2 min to unhook the battery. A lot longer to diagnose a fried electrical system.
Old Dec 28, 2009 | 07:57 PM
Stuntforlife's Avatar
Wink
no a jump box will work fine. but like MC said, make sure the charger is set to a 12 volt setting. no need to charge fast either. and you can leave stuff hooked up while charging, not suggested but you can... i jump start mine sometimes from a car... and jump box and a charger ha ha...
Old Dec 29, 2009 | 09:29 AM
chuckbear's Avatar
You'll be fine with it as long as you can use a low setting (2 amps or less).
Old Dec 29, 2009 | 12:04 PM
hondajunkie's Avatar
Official Welcome Crew Junkie
I agree indubadidly (did I spell that right? lol)
12volts...LOW amperage.
High amps will fry the battery
Old Dec 29, 2009 | 02:44 PM
Zero1080's Avatar
Take it out. IMO, it's MUCH easier to work. I take mine out, keep it in my room, sitting on my desk, and just leave it plugged in all winter.
Old Dec 29, 2009 | 03:53 PM
A little side note on battery removal, Therea a hole in the bottom of the battery box so you can push it up and out instead of tugging on it from the top. I've had that battery out a dozen times and never noticed it. Duh!
Old Dec 29, 2009 | 05:03 PM
Seafordguy's Avatar
Yep - and or pull the cables off, then put the bolts back in and use the heads of the bolts to grab with a pair of Vice Grips...
