battery ?
it seams that my battery has to be charged about once a month. and if i do a lot of running around in one day my battery gets so weak it wont start and i have to jump it or pop the clutch. and its also a new battery
Your charging system is bad. Voltage Regulators/Rectifiers are known problems on F2's. It is easy enough to run a diagnostic using a simple voltage meter. Your electrical system runs off your battery, so it is something you want to repair ASAP, unlike cars that run off the alternator. Voltage Regulator will run about $115.00 if you need one. Stock Honda Part is closer to $200.00.
Eventually you will ruin your battery if you don't repair your charging system, that will add another $50.00 or so to your repair bill.
ORIGINAL: bubba_d_duck
do you think a 1997 Honda CBR 600 F3 Voltage Regulator would work on my 92 cbr 600 f2?
But to be safe, you might ask a Honda Parts guy.
jharbinson
Dec 31, 2009 09:23 AM
