Clutch adjust
Old Jul 2, 2007 | 10:52 AM
rebel3.0's Avatar
Default Clutch adjust
Hey guys new here, and to motorcycles in general. I just bought a 88 600 cane and it has troubles going from first gear to nutreal. I was thinking that the it might be out off adjustment because the clutch was just replaced. I should also say that the bike goes in nutreal fine with the engine off. How do you adjust the clutch ?
Old Jul 2, 2007 | 02:36 PM
michigan_313's Avatar
Default RE: Clutch adjust
remove right side fairing. there you will see clutch cable and adjustment barrel and lock nut. there should also be a fine adjustment barrel on the clutch perch under the rubber boot. use the adjustment at the bottom to take out any slack. then use the top adjustment for fine tuning.
Old Jul 2, 2007 | 03:14 PM
rebel3.0's Avatar
Thank you for the reply
asides
May 6, 2011 12:16 AM
itgbudeev
Jun 25, 2008 03:48 PM
j0n
Aug 6, 2007 01:06 AM
FastCRX
Sep 8, 2006 09:26 PM
Rev
Mar 14, 2006 03:46 PM
