unknown cable?
Old Jul 2, 2007 | 06:19 PM
camoweasel's Avatar
Default unknown cable?
What is the cable that is next to the throttle cable coming down fromthe handlebars?
Old Jul 2, 2007 | 06:44 PM
Micro Rotors's Avatar
Default RE: unknown cable?
Hello camoweasel,
There are 2 coming from the throttle assembly (push-pull), and then there is the front brake cable.
Hope that helps!
Bill
Old Jul 2, 2007 | 07:06 PM
camoweasel's Avatar
is there a way to adjust the push one so that the throttle snaps back into position because mine isnt doing it properly. I have to manually turn it back. The service manual only says to adjust the one with the set screw.
Old Jul 2, 2007 | 07:32 PM
michigan_313's Avatar
before doing any adjustment, you may want to clean and relube the cable housing first. then (if you so choose) remove the fuel tank and airbox to uncover the carb set. clean off the springs that the throttle cable is attached to and anything else that might be dirty. then check your throttle movement to see if it gets hungup anywhere. after that, you can start making your adjustments. if you are manually shutting down your throttle, you may have too much slack to adjust out. most of that needs to be taken out at the carb end of the cable. the barrel adjustment is mostly for fine tuning.
Old Jul 2, 2007 | 10:15 PM
ORIGINAL: michigan_313
I couldnt have said that any better!
Charlo
Aug 13, 2014 10:49 AM
neeganate
May 28, 2013 08:12 PM
L2tg-blitz
Mar 13, 2011 11:25 AM
NinjaViper
May 25, 2010 09:10 PM
hotwire
May 26, 2006 04:50 PM
