Can I adjust the clutch lever on the 05 RR?
RE: Can I adjust the clutch lever on the 05 RR?
You can adjust the clutch freeplay in the handle but u still have to extend a lot to engage. You can also adjust the quickness of the engagement but the closer you adjust it the more the clutch stays partially engaged so it burns your clutch up faster. I found this out when i wanted to do the same thing.
