battery question
Old Oct 12, 2015 | 05:03 AM
87 cbr 600f's Avatar
Default battery question
hi all just been given 6 of these brand new unused batterys my question is could i use one on my 87 cbr 600f the book says the cbr 6 needs 8 amp one these are 7
Old Oct 13, 2015 | 01:25 AM
Wesku79's Avatar
Yes, you can use it - if it physically fits in the battery tray.
There is just slightly less stored power for starter motor in case if your bike doesn't want to start up. I mean like with 8 amps you can keep cranking 8 minutes and with 7 amps 7 minutes. (I don't mean real minutes here, only to figure the meaning of battery capacities)
Old Oct 17, 2015 | 02:53 PM
reaper101's Avatar
does it fit your battery tray? slap it on and test it out, you should be fine tho test it out for a couple days see if it gives you any issues, your using a carb bike they require a lot less electrical than a fuel injected bike you should be fine but after a couple of days get your volt meter and check that voltage man, dang wish you were near me i need a new battery lol
Old Oct 22, 2015 | 06:23 PM
they are identical size to the 8 amp cbr battery and fit in the battery box the same too lol @ reaper101 you need one too then eh
estate4life
Dec 4, 2012 11:08 PM
jharbinson
Dec 31, 2009 09:23 AM
sempul
Sep 11, 2009 09:38 PM
njdjh2o
Apr 11, 2008 07:20 PM
MDZ600F4i
Oct 18, 2006 07:50 PM
