battery question
1 Attachment(s)
hi all just been given 6 of these brand new unused batterys my question is could i use one on my 87 cbr 600f the book says the cbr 6 needs 8 amp one these are 7
Yes, you can use it - if it physically fits in the battery tray.
There is just slightly less stored power for starter motor in case if your bike doesn't want to start up. I mean like with 8 amps you can keep cranking 8 minutes and with 7 amps 7 minutes. (I don't mean real minutes here, only to figure the meaning of battery capacities) |
does it fit your battery tray? slap it on and test it out, you should be fine tho test it out for a couple days see if it gives you any issues, your using a carb bike they require a lot less electrical than a fuel injected bike you should be fine but after a couple of days get your volt meter and check that voltage man, dang wish you were near me i need a new battery lol
they are identical size to the 8 amp cbr battery and fit in the battery box the same too lol @ reaper101 you need one too then eh :)
