Is There A Thread for Brake Adjustments???
Old Oct 17, 2005 | 06:59 PM
throttleone's Avatar
Default Is There A Thread for Brake Adjustments???
wassup folks just wanted to know if there was a thread on braked adjustments for the 1000rr, if not can anyone tell me how to adjust my brakes? lets say the brake lever is braking real close now than before without changing the length of stroke or does this mean i need brakes... well please let me know and thanks for reading this important post.......
Old Oct 17, 2005 | 08:28 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Is There A Thread for Brake Adjustments???
You got the dial that sets the length of travel for the lever. If you haven't changed that and the travel is different then you could be wearing the pads a bit. Check 'em out cause the rear isn't good for much except trail braking and holding it still at a light[:@]
Old Oct 18, 2005 | 03:44 PM
Anubis's Avatar
Ditto on the adjuster dial, check your brake fluid level too if its low its normally a good sign you need new pads. Change em yourself if ya do it`s a 10 min job.
live4liftin
Feb 9, 2013 08:29 PM
SoloRider
May 23, 2009 12:14 PM
bmg velocity
Dec 27, 2007 09:20 AM
Glocker23
Jul 5, 2007 09:12 AM
kbuck900RR
Jun 10, 2007 11:06 PM
