Is There A Thread for Brake Adjustments???
wassup folks just wanted to know if there was a thread on braked adjustments for the 1000rr, if not can anyone tell me how to adjust my brakes? lets say the brake lever is braking real close now than before without changing the length of stroke or does this mean i need brakes... well please let me know and thanks for reading this important post
You got the dial that sets the length of travel for the lever. If you haven't changed that and the travel is different then you could be wearing the pads a bit. Check 'em out cause the rear isn't good for much except trail braking and holding it still at a light[:@]
Ditto on the adjuster dial, check your brake fluid level too if its low its normally a good sign you need new pads. Change em yourself if ya do it`s a 10 min job.
