low end engine lag
Old Sep 23, 2005 | 08:27 AM
  #31
mmookey's Avatar
Default RE: low end engine lag
Sorry about that. Maybe dial up your clutch so that it engages sooner? Just throwing things out there seeing if something works.
Old Sep 26, 2005 | 05:11 AM
  #32
jcf1977's Avatar
I've read that the closest map for the Jardine is the map for the Erion. This will clean up your bottom end right from the get go.
Old Sep 28, 2005 | 03:51 PM
  #33
shinysideup's Avatar
i wroter to tech support at power commander. they told me to use the micron. dont get me wrong, the bike runs fine above about 2.5k, but, unless i am pegging it off the start and slipping the clutch more than usual, it starts real slow and has to work past a big dead spot before the power kicks in. it isnt the end of the world, but it never did that with the stock pipe. nor did any of my friends. it has to have something to do with the pipe. is there anyway i can add a little back pressure just to the bottem end?
Old Sep 28, 2005 | 07:51 PM
  #34
Anubis's Avatar
Sounds like its runnin lean before 2500 revs, either use the buttons to richen it up a tad or if you look at your map your using on the computer you can change the fueling by increments of 250 rpm richen the map a little for under 2500 revs and see how it runs,
Old Sep 28, 2005 | 08:00 PM
  #35
chainstretcher's Avatar
Admin Emeritus & MVN
I'd be inclined to think it's a bit rich down low. The last two bike I put a PCII on with a pipe were spot on from 4K up but rich as hell down low. Either way, too rich or lean, and it's not gonna perform at its best. This is something that would bug the she-yat outta me til I figured it out.
Old Sep 28, 2005 | 09:12 PM
  #36
TeeDub's Avatar
Usually too rich (too much fuel) down low will cause it to bog. Leaner is faster, till you blow her up!
Old Sep 30, 2005 | 05:04 PM
  #37
i tried leaning and richening it up with the buttons. leaning didnt do much, but richening it up even a little caused it to have some pop in the exhaust. i cant fully tell if it is rich or lean. i would think rich, due to flowing more air now with the exhaust and not changing much to the fuel. all i have done was add the power commander and load the map. will it change anything differently if i change it on the map instead of the buttons? give me some ideas. what about all the numbers on the map? im guessing the bigger # flows more fuel and smaller is less. should i just tinker with the numbers one at a time and see what they do? i do know that the lower settings are at 0.
Old Sep 30, 2005 | 06:00 PM
  #38
This is the area where a sniffer on a dyno is a wonderful thing. I suggest reloading the map and then adding fuel 10 at a time below 3K rpms and see how it runs. If it gets more lag then go the other way. The buttons are practically useless and have a tendency to do weird things to your entire map. I don't even know why they put them on there. So the best of all worlds would be a custom dyno map with A/F ratio but if you just mess with the below 3K rpm setting you should be o.k.
Old Sep 30, 2005 | 09:59 PM
  #39
sweet, thats tomorrows project
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
julius1
CBR Zone
Jan 4, 2010 11:32 PM
98formulaLS1
Aug 24, 2009 10:04 AM
Workwell
Jan 14, 2009 10:02 PM
