low end engine lag
Old Sep 1, 2005 | 12:34 PM
05Tribal's Avatar
Default RE: low end engine lag
ORIGINAL: mmookey
You can go on the Powercommander web site and go to the animated tutorials to get a detail explaination. All you have to do is plug into your PCIII, establish connection with the unit (Key on and Switch to run), go to Powercommander tools, select throttle position and click the < Key. Your display will show 0% at idle. Now your throttle is recalibrated. You can do this with the bike on or off. I wanted a true setting so I did it with the bike running.
Thanks!
I just need to take some time this winter when things slow down and take a close look at everything the PC can do.
Adam
Old Sep 4, 2005 | 02:00 PM
shinysideup's Avatar
got the pc3 yesterday. ill probably put it on tomorrow unless its a lot harder than i think. ill let you know how it goes.
Old Sep 4, 2005 | 02:42 PM
Weatherman's Avatar
hey directions for installation kinda sucks, I thought. Hardest part is getting at the throttle bodies. Solution is to unbolt front bolts for the tank and pull tank back. Good luck!
Old Sep 4, 2005 | 03:25 PM
chainstretcher's Avatar
Admin Emeritus & MVN
When pulling the tank use some soapy water on the rubber boot that's around the filler cap -- can be quite a pain in the ****[:@]
Old Sep 5, 2005 | 10:55 AM
yea, it does require a lot of dissasembly, but i have had it broken down more than that already. it will probably be a few days before i get the time to install it
Old Sep 5, 2005 | 01:23 PM
Anubis's Avatar
no more than 15mins work, take it easy with the plastic clips on the throttle bodies don`t wanna break ay tabs.
Old Sep 6, 2005 | 06:18 PM
i dont know if anyone is looking for or knows where to find a pc3, but i got mine from the honda shop. i highly advise that no one does the same. it was 390$, ouch. the next day i found it at dennis kirk for 316 plus free shipping. just to let you all know
Old Sep 7, 2005 | 08:09 PM
ok, so i got the pc3 installed. now, im a little clueless. i installed a jardine slip-on and that is all of the performance stuff that it has recieved. so back to the low end engine lag...what am i going to have to adjust to get it to run properly?
Old Sep 7, 2005 | 10:48 PM
mmookey's Avatar
I know that Powercommander does not have a custom map for the Jardine muffler. Did you download anything from Powercommander? Sounds to me that now you have to have it dyno.
Old Sep 8, 2005 | 01:47 AM
I'd suggest downloading maps for other slip ons and try them out. Still unsure why your bike lugs. Can you do a burnout on your bike? If so, then next time you launch pretend that you're doing a burnout only don't squeeze the brake.
