chain?
Dont run it TOO tight.........that will ruin a chain faster than anything. Leave enough so that when the swing arm is straight..........at it's straightest point that you have some slack........that means sit on it........and put a passenger on it......THEN adjust it.......but leave enough slack so that a sharp bump wont pull it tight........looser is better than tight.
But yes......as he said.........slide the rear wheel back STRAIGHT........one turn of the wrench on the left side means you need one on the right too!!
Count the points on the hex nut as a reference to maintain straightness. Or you can buy a tool that makes it much easier from Motion Pro (chain alignment tool), I bought one from indysuperbikes for fairly cheap...cheaper than a rear sprocket or chain anyhow.
Counting turns? Counting points on the nut? Isn't going by the dash marks on both sides of the swing arm good enough? I don't think when the put your bike together they are counting turns or points BUT I could be wrong.
davedude44
Jun 28, 2012 12:22 PM
ajc8054
The Hurricane Saloon
Aug 15, 2010 02:28 PM
crookedeyemotocross
May 4, 2006 10:14 AM
