exhaust heat
Old Jun 16, 2007 | 02:15 AM
bboi's Avatar
Default exhaust heat
Does anyone have any ideas on tryin to cut down on exhaust heat. I dont mean the pipe itself just the exhaust fumesthatare leaving the pipe.
Old Jun 16, 2007 | 11:21 PM
1fasthonda's Avatar
Default RE: exhaust heat
Don't run it. Thats the only way I know.
Old Jun 16, 2007 | 11:47 PM
bboi's Avatar
Dont run it? Aight thanks for that Ill make sure to push my bike everywhere lol
Old Jun 17, 2007 | 02:32 PM
unforgiven's Avatar
I guess the question needs some clarification as to why you ask? You are concerned with the heat of the exhaust itself. Are you getting some negative affects from it like tail light getting melted or such? Removed heatshields? Just curious. I have no idea how to reduce the heat of the exhaust. As long as the pipe extends far enough behind the light and you are not melting parts because of your heatshields being removed, is it a problem?
Old Jun 17, 2007 | 03:23 PM
bboi's Avatar
nah no problems just a precaution
Old Jun 17, 2007 | 03:28 PM
christhek's Avatar
A precaution for what? Why do you think it is a problem. Never heard of anyone concerned about the temp of the actual exhaust fumes. If they aren't damaging anything and if your engine is runnning properly, what is the problem? More clarification is needed as to why you are concerned with this.
Old Jun 17, 2007 | 03:59 PM
bboi's Avatar
I just asked a question.The answerwould be the same regardless if you know why I asking or not.But here goes. Just a precaution on not melting the taillight or nose cone of the jardine. I had to modify the bracket so the cone is slightly closer to the tail section an wanted to make sure it wasnt goin to melt anything. That and why not want to cool your over all bike down. Ima try the engine ice deal, but was asking on here to see if anyone else had clues.
Old Jun 18, 2007 | 04:02 PM
1fasthonda's Avatar
Engine Ice works well I have it in mine. If you have your stock exhaust or slip-on you can wrap your factory headers in ceramic to keep the exhaust heat off your radiator and engine. This also keeps the exhaust hot and moving faster and it will exit out the bike quicker. The stock headers are thick enough to with stand the heat from wrapping but aftermarket pipes are a lot thinner than stock and there for you can't wrap them. You can also put heat tape on your undertail if your concerned about heat.
Old Jun 18, 2007 | 04:46 PM
2wheels's Avatar
bboi:
If you wrap any part of the exhaust that will only make your exhaust gas hotter.A heat shield would be your best bet.
tofastgt
Jun 29, 2010 10:43 PM
Boab
CBR1000F Wanted / Swap
Apr 29, 2010 01:49 AM
Ian Evans
Jan 23, 2009 01:58 PM
jerrad
Jul 7, 2006 06:23 PM
TeeDub
Nov 7, 2005 09:34 PM
