Exhaust heat shield, do I need it?
Old Oct 20, 2005 | 08:51 PM
TeeDub's Avatar
Default Exhaust heat shield, do I need it?
I just installed my Ti Akra slip on last night (lightly used off ebay, $400!) and the factory heat shield under the tail looks like crap. Do I really need to keep it? How about trimming it so you can't see it, or how about using some of that metallic/foil type adhesive heat shield tape stuff on the undertail?
How many of you guys are running pipes with out the heat shield and has it caused any problems?
btw, its a 2004 cbr1000rr.
Old Oct 20, 2005 | 11:35 PM
MgA_ODEN's Avatar
Default RE: Exhaust heat shield, do I need it?
Toss it , most people ( me included ) do.
Old Oct 21, 2005 | 02:21 AM
TeeDub's Avatar
Did you put anything else under there for protection, or just a la natural?
Old Oct 21, 2005 | 07:44 AM
Anubis's Avatar
I did away with the original heatsheild too, when i installed the RS5 it came with a stick on one that you cut to size and use. I did use this and didn`t notice any difference in heat from under there.
Old Oct 21, 2005 | 09:10 AM
05Tribal's Avatar
I trimmed mine down so it looks factory. With in installed over the new pipe I took a sharpie and drew lines where I wanted to cut then I removed the shield trimmed it then replaced it. It looks great.
Old Oct 21, 2005 | 02:12 PM
TeeDub's Avatar
ORIGINAL: 05Tribal
That is exactly what I was going to do, hell, if I had a 4" angle grinder I'd do it like the Tuttles! I have some metal shears though that will probably work much better.
Old Oct 21, 2005 | 09:50 PM
05Tribal's Avatar
I used metal shears and a bench grinder to smooth the edges.
Old Oct 24, 2005 | 08:42 PM
Charliesays..'s Avatar
Does it make much difference for heat?
Old Oct 25, 2005 | 02:53 AM
TeeDub's Avatar
I trimmed it up nice and neat and painted it flat black with some high temp engine paint. Looks great, or should I say, you can't even see it!
Old Nov 7, 2005 | 09:34 PM
Stonecold34gixxer's Avatar
Good on ya mate!
BTW Nice call on the SV for the newbie.
fisher1882
Mar 8, 2011 02:28 AM
swift25
Apr 7, 2009 10:58 AM
gotobatter
Jul 10, 2008 12:28 PM
gotobatter
Apr 13, 2008 12:21 PM
transamlt1man
May 5, 2007 11:51 PM
