wont start anyone have ne ideas.
well i just got done changing the oil and the plugs. The bike started saturday night after i had trouble with the fuse and after i changed that fuse it ran.
now i cannot get it started for the life of me. I checked the plugs they are wet with fuel so i know it is getting gas. I pulled all four of them and cranked the bike over a couple times incase it was flooded put them back in and it wont start.
the only other thing i noticed was it seemed like there was some oil around the part where the washer is on the bottom. If anyone has any ideas please let me know i am confused as to why it would run saturday but not again on sunday.
RE: wont start anyone have ne ideas.
Oil pressure light will flash until the engine fires, at which point it should go out. Don't see a problem there. Problem sounds electrical though - maybe the black ICM ? Hope not.....[X(]
I'm suspicious of the kill switch - they can often be a real villain !
If it is getting gas I would confirm spark by pulling a plug and resting it on the head while cranking the engine over. You should see spark.
Are the plug wires in the correct location? Looking down from the riders position the left coil wires go to #1 and #4. The right coil wires go to #2 and #3.
ORIGINAL: collector
Before you go through the prosses of checking the wiring check first your kill switch and if you have on the nutral sencor as this will kill the power to the bike. Hope you get it sorted.
