Making noise under 4000rpm
Old Jul 27, 2009 | 08:45 PM
voland's Avatar
Default Making noise under 4000rpm
Cbr 1000 SC21 1987
When driving a few miles I hear a ratteling scary noise in all gears except when I turn into neutral. When I rev up 4000rpm+ the noise dissapears.
I have changed the cam tensioner and complete clutch, no differance.
When the oil is cold the noise is away.
I think it has something to do with the gearbox, Can I trow my engine away? Because this is my second engine and I dont want to split it.
share your expertise please,
greets from europe-the netherlands
Old Jul 28, 2009 | 04:57 AM
bluebeard's Avatar
Where is the noise from? Is it from the top, the bottom or somewhere in between? If you can't pinpoint the spot try & use a large screwdriver as a stethoscope.
If it's the bottom then alternator chain & tensioner or gearbox which means split the cases. In the middle then possibly starter damper. Easier to split the cases. Splitting the cases although a big job is not overly difficult & not to be frightened of. Just takes a bit of care more than anything.
Just had a thought. Have you checked the balance shaft adjustment. They can rattle if way too loose as can valve adjustment especially if an adjuster has come loose.
Old Jul 30, 2009 | 05:31 PM
pablohoney's Avatar
Maybe this isn't what you are talking about, I am kinda new, but I know that my cam chain makes noise up to about 4000rpms then stops. It isn't major noise but a definite rattling. From what my mechanic tells me, it is just how the bike was made and not to worry about it. Anyway hope this helps.
Taylor
Old Jul 30, 2009 | 08:19 PM
Sprock's Avatar
Talking .......putting off the inevitable
Classicman...............you and about another half dozen on here are in the
same boat putting off the CCT job. Way I see it is ............I have to wait
for the winter weather 'cause we all know it's always better to take their
tops off in cooler weather
markybwoi
Oct 29, 2022 02:32 PM
loyerj2
Jun 28, 2010 04:31 PM
TedBull
F2 Tech
Jun 2, 2010 11:16 PM
quaddict53
Dec 30, 2008 12:08 PM
etherimos
Feb 20, 2008 11:14 AM
