Sprocket change question
Old 05-04-2017, 03:01 AM
silverf1's Avatar
Default Sprocket change question
I'm thinking about going +2 on my rear sprocket.
My bike is a low mile excellent shape and I don't want to throw the odometer off from actual. Will going +2 on the rear make that much of a differance? If it's extremely minimal then I'll be ok with it.
Also, with a stock front sprocket and going up 2 in the rear, will my stock chain length most likely be ok?
Thanks for any input!
Old 05-04-2017, 07:04 AM
74demon's Avatar
If your speedometer drive is on the front wheel, then changing the sprockets won't make a difference.
I don't have a 1000f, but I think yours does drive off the front wheel.
if the pick up is in the trans, like my rr, then it will be off a bit.
Old 05-04-2017, 07:25 AM
silverf1's Avatar
It's a 90, so speedos not off the front wheel. I wonder roughly how far it would be after say, 5000 miles?
Old 05-04-2017, 09:18 AM
74demon's Avatar
http://www.gearingcommander.com
have a look at that link. It will give you some numbers to compare,, but not sure about distance.
You could get a speedohealer to correct it, if it's electronic.
rdsii64
11-06-2014 08:42 PM
89HurricaneF1
05-07-2012 09:52 PM
sickmefistofeles666
07-28-2009 09:07 AM
otisdr
08-07-2006 06:51 AM
Quick Reply: Sprocket change question
