Backfife/oil leak
Old 04-21-2013, 03:11 PM
Timo's Avatar
Default Help needed, Backfire/explosion/oil leak CBR1000F -92
Greets from Finland guys!
After long long winter, normal season start maitenances done, battery on its place, short cranking and all fine. Bike did work really fine, nothing but out and road. After first 200 km's and refueling. mr Murphy arrived...
When started bike in gas station, kaboom!
It seems like carbs have floated while filling tank. Since I started bike again, sounds like engine sneezed once... it blowed smoke from exhaust like in backfire, but also raised pressure in cam chamber a lot and immediately pushed oily smoke like there was spilled oil to hot exhaust manifold....
Any new noises from engine can't be hear, it idles nice, no power loss, engine runs fine up to top rpms BUT leaks oil now somewhere from engine left side....
Have anyone experience about something like this??
My understanding will end to ignition point...
If cylinder is filled with gasoline, shouldn't it broke cam shaft or something quite easily?
If cylinder head gasget will brake down, should't it reflect to engine behaviour some way. I didn't notice any abnormal in engine temperature and like I mentioned, engine seemed to work fine...except oil leak....
Timo
Last edited by Timo; 04-22-2013 at 06:38 AM. Reason: Spellcheck and additional info
Old 04-21-2013, 10:33 PM
slowpoke's Avatar
Originally Posted by Timo
Greet from Finland guys!
... But leaks oil prom top of cylinder head...
Anyone got experience about this kind...
Ideas what was happened? And checks to do??
Timo
Spark plug fell out?
Old 04-23-2013, 08:40 AM
Sprock's Avatar
check your valve cover gasket hasn't popped
Old 04-23-2013, 11:33 AM
bicklebok's Avatar
This may be a dumb suggestion, but check your oil and make sure its not full of gas too.
ko67
F2 Tech
09-20-2011 10:47 AM
graysonwittwer
08-17-2011 05:40 PM
amir145
09-01-2010 11:33 AM
smitty911
04-23-2008 01:42 AM
airick
04-17-2007 06:58 PM
Quick Reply: Backfife/oil leak
