Another tire question
Old Feb 10, 2024 | 09:56 PM
konatodd's Avatar
Default Another tire question
I’m wondering if anyone has experience with the Kenda KM1 tires in 160/60VR17 size on an 87 or 88 CBR 1000F?
I have been using the search function but it is not easy to find, from what I’m reading the 87,88’s has narrower tires then the later models?
Anyone see an issue? I can get them at a good price.
TIA
Old Feb 11, 2024 | 01:25 AM
dannoxyz's Avatar
Your bike came with bias-ply tyres matched to those rims.
KM1 is modern radial tyre designed to work with wide rims (wider than bias-ply tyre of same width). The 160/60vr17 size needs 5.0” wide rim to work. Squeezing them onto narrow rims will cause all sorts of problems. The pinched pointy contact patch will cause faster wear. Sidewalls will be too curved and you’ll lose grip and slide easier.
Get proper size tyres for your rim-width. Or upgrade to wider rims. I put CBR600F2 rear wheel on my ‘86 VFR so I can use modern 17” radial tyres.
Old Feb 11, 2024 | 06:33 AM
konatodd's Avatar
Perfect! That’s kind of what I figured, I will just look for the stock size and see what I can find.
Thanks!
mdowney421
Apr 5, 2012 05:56 PM
FoCoCBR
Feb 21, 2011 01:09 PM
Indiana Hurricane
Oct 14, 2009 10:10 AM
98f3pilot
Nov 23, 2006 06:18 PM
ddvs
Aug 28, 2006 02:58 AM
