led turn signal problem
Old Apr 13, 2010 | 05:22 PM
77vetteguy's Avatar
Default led turn signal problem
I bought these turn signals for my 05 600rr. The problem is that there is no base for them to mount to the place where the old signal was. Has anyone done this before? If you have what did you use to tighten down the signals?
this is what needs to be covered up.
These are the only adapters I can find but the're for the front blinkers and different cbr models.
Old Apr 13, 2010 | 08:43 PM
Turbulenz's Avatar
Official Welcome Crew
Isnt there some kind of insert (maybe made of rubber) that goes into that oval that has 2 circular holes for mounting and wiring? Check the end of your stock signals....
Old Apr 13, 2010 | 09:44 PM
77vetteguy's Avatar
yes it does but its too thick for the bolt on the new blinker to go all the way through.
Old Apr 13, 2010 | 09:45 PM
77vetteguy's Avatar
These are the signals.
http://photos.imageevent.com/bikeguy...ELED-W-3-2.JPG
Old May 8, 2010 | 11:20 AM
TooBroke0029's Avatar
my recommendation would be to try and use the stock base just go to home depot or menards and see if there is a way you cane extend the bolt. just m.o.
Old May 12, 2010 | 09:14 PM
xhyperxshogunx's Avatar
go to homedepot or lowes and buy some plexiglass scrap and cut it to cover the stock hole..then drill the hole for the new turn signal.
Old May 16, 2010 | 11:53 AM
nlh8584's Avatar
get rid of the ugly mud flap and do a fender eliminator then drill your own holes for where you want to put them
Fallen3
Sep 28, 2010 03:56 PM
RoosterF3
F2 Tech
14
Apr 10, 2010 09:26 AM
utter05
Jan 22, 2009 01:10 PM
Stugots
May 1, 2008 03:51 AM
dewthedoo05
Sep 4, 2007 09:32 PM
