05 f4i flush mount question
WildChild got a new battery it started still no temp tach speed.....checked all my fuses and the 10A third or 4th down it says Ind, taillight and somethin else dont member,,,, but it keeps blowing im thinking my new LP racing LED taillights might be blowing it out ins the IND mean indicators or somethin like that? does a fuse run the dash? i blew my spare when i changed it right on start up it blows,,,,, the odd thing is the signals work perfect front and rear and brake light i just have no tail lights or dash god I hate electrical
also does anyone know if this is bad to wire the signals i spliced the green with the blue and white stripe and then the orange with stripe to the green and the other side single tap to the new flush mount signals. the signals blink at normal speed but theres no running light should i re wire could that have caused my problem wil that kill my battery? or could that have made the tach speedo and temp not work? also why would my tail lights not be working?? but th signals do and brake light with the 10An 3rd or 4th fuse that says taillight ind and somethin else keeps burnin
seperate all of your wiring up front...if you grounded your running lights up front i would bet they are on the same ckt as the tail lights...
go to this web site and you can grab a pdf copy of the F4i service manual...it can give you complete wiring schematics...
http://stephygee.com/
its in the bottom left corner...just click on the F4i and it will let you download it...
well i have seen folks do it but i do not know what the long term harm may be...
you can find plenty of cheap slipons between ebay and craigs list...i paid 130 shipped for my D&D...its the most badass sounding pipe for the F4i...it sounds soo crisp...but earplugs are required
