Heat Shield Removal
Old Nov 19, 2005 | 03:22 PM
rocketdogbert's Avatar
Default Heat Shield Removal
del
Old Nov 19, 2005 | 03:27 PM
TeeDub's Avatar
Default RE: Heat Shield Removal
A lot of guys remove it all together. Putting heat reflective foil under there would be a good idea. I just marked mine to follow under the tail and cut it with some good sheet metal shears. I then painted it matte black with some high-temp engine paint. You don't even notice it under there now, but it still does its job. Be carefull washing under there though, the edges of the heat shield are sharp after you cut them!
Old Nov 19, 2005 | 03:52 PM
del
Old Nov 19, 2005 | 04:31 PM
chainstretcher's Avatar
Admin Emeritus & MVN
I left my heat shield as it was and modded the plastic bits that most people toss.
Old Nov 19, 2005 | 05:10 PM
Anubis's Avatar
I tossed it, well its hanging in my garage, and used the stick on heat reflective material that came with my rs5 much neater and haven`t had any heat problems.
DevilInDisguise
Mar 31, 2012 10:38 AM
bowflexmaverick
Jan 12, 2011 04:45 PM
gotobatter
Apr 13, 2008 12:21 PM
danny600rr
Dec 17, 2006 06:34 PM
cbrrookie
Mar 23, 2006 07:52 AM
