Should I Convert? Is it Permanent?
Old Apr 13, 2014 | 11:06 PM
Darin Agan's Avatar
aloha conrice! have another question why is it ,! i'm changing the clutch cable its new and longer came with the kit with the topyokes and when i switched the cables and its longer its so tight when pulling the clutch there is no play please any help advice will help me on this !
Old Apr 13, 2014 | 11:26 PM
Conrice's Avatar
Red face
Pulling the lever is tight?
If the lever pull is too tight, you'll just need to adjust it and maybe shoot some chain/cable lube down the inside of the cable lining.
What about the play? Are you saying the catch point/friction zone is too small or too close to where the clutch lever is all the way out or too close to the lever is pulled all the way in?
That again, should be adjustment. You should be able to adjust the lines at the lever, at the perch, and at the clutch cover.
You'll have to try different adjustments to where it feels right for you.
sethb85
Sep 27, 2012 05:09 PM
KenG
May 30, 2012 06:43 AM
fiddy_nutz
Aug 3, 2010 11:19 AM
thegatekeeper14
Aug 10, 2009 05:17 PM
Pacs_Legend
Nov 2, 2007 06:04 PM
