Ram-air Effect/Petcock Vacuum
Old Oct 13, 2012 | 06:43 PM
Ls1Mx5's Avatar
Default Ram-air Effect/Petcock Vacuum
I've heard that without fairings on my Cbr600f2 I will experience a ram-air effect that will cause it to run lean. To fix it, someone suggested taking the float chamber vents between carbs 1&2 and carbs 3&4, attaching them to a tee and running it into the airbox through a hole drilled in the underside just large enough to pass the hose through tightly. I want to do this correctly so I have some questions.
Also, I was told by someone else that the cylinder 1 vacuum line should attach to the petcock and the cylinder 2 vacuum line should be capped. Right now the cylinder 1 and 2 vacuum lines are tee'd and that tee line leads to the petcock. How should this be?
Here are the pics:
The two lines in this pic that are horizontal over the carbs are the ones that should be tee'd and brought to the air box right?
This is the vaccum from cylinder 1 I was referring to
Here's the tee that connects the vacuums from cylinder 1 to cylinder 2. The other end goes to the petcock
I plan on drilling the hole in this part of the airbox between cylinder's 2 and 3. Is this a good spot?
Thanks a lot in advance to who ever helps. Sorry for my dumb questions
swaskowiak
F2 Tech
Jul 9, 2019 02:29 PM
Ls1Mx5
F2 Tech
Dec 31, 2012 01:09 PM
robrea19
Jul 20, 2012 08:56 AM
jk72180
F2 Tech
May 9, 2011 12:25 PM
Mrmanr
Mar 11, 2011 03:49 AM
