Ram-air Effect/Petcock Vacuum
I've heard that without fairings on my Cbr600f2 I will experience a ram-air effect that will cause it to run lean. To fix it, someone suggested taking the float chamber vents between carbs 1&2 and carbs 3&4, attaching them to a tee and running it into the airbox through a hole drilled in the underside just large enough to pass the hose through tightly. I want to do this correctly so I have some questions.
Also, I was told by someone else that the cylinder 1 vacuum line should attach to the petcock and the cylinder 2 vacuum line should be capped. Right now the cylinder 1 and 2 vacuum lines are tee'd and that tee line leads to the petcock. How should this be? Here are the pics: The two lines in this pic that are horizontal over the carbs are the ones that should be tee'd and brought to the air box right? https://lh6.googleusercontent.com/-m...1312173945.jpg This is the vaccum from cylinder 1 I was referring to https://lh6.googleusercontent.com/-g...1312174035.jpg Here's the tee that connects the vacuums from cylinder 1 to cylinder 2. The other end goes to the petcock https://lh3.googleusercontent.com/-G...1312174055.jpg I plan on drilling the hole in this part of the airbox between cylinder's 2 and 3. Is this a good spot? https://lh6.googleusercontent.com/-k...1312174249.jpg Thanks a lot in advance to who ever helps. Sorry for my dumb questions |
