Honda cbr 125 r gas tank problems
Old Mar 19, 2022 | 05:27 AM
Marre's Avatar
Default Honda cbr 125 r gas tank problems
2005 model
I've looked around online for solutions but have not been able to find much.
My issue is that when the fuel tank is connected the bike won't start. But if i use a bottle with gas in it and push it inside the carb it starts and runs pretty good. Carb is clean, battery new, bike only has 7500km. What may be the issue? I've seen someone talking about fuel filter i've just not even been able to find where it's located. Also talked with a few ppl and they said that fuel pumps rarely give out.
Old Mar 19, 2022 | 09:09 AM
Do you have flow from the tank itself if you simply pull the fuel line?
Old Mar 20, 2022 | 10:32 AM
Marre's Avatar
Yes, I have flow from the fuel tank. We drained the carb and checked if fuel kept coming out when we started it which it did. Yesterday we got it running the biked idled for a good 5 minutes then i wen't out to drive it but it stalled after driving for 15-30 seconds. I held the idle pretty high for a while too. So idk it this is with any help.
Old Mar 20, 2022 | 11:20 AM
With the tank connected, try opening the fuel cap and see if that makes a difference. If so, your vacuum line is blocked/pinched.
Old Mar 20, 2022 | 11:56 AM
Marre's Avatar
If that was the problem, wouldnt no gas come to the carb?
Old Mar 20, 2022 | 12:11 PM
No not necessarily. It can work for a while until the vacuum pressure inside the tank gets to be too much. Thank of a jug that you are pouring out fluid. If it doesn't have a vent hole the fluid flow isn't smooth. Create or open the vent hole and everything pours freely.
Another symptom is when the bike is running and you start to experience the issue and you open the cap, if you hear a sucking or whooshing sound, that is a clear indicator of breather tube issues.
Old Mar 20, 2022 | 12:24 PM
Marre's Avatar
Alright will try it thanks for the help
TenkateVegas
Nov 1, 2012 07:35 PM
Willkster
Apr 27, 2010 05:34 AM
CBRfenatic93
Mar 2, 2010 02:14 PM
Witchking
May 12, 2007 09:05 AM
coledurango
Nov 8, 2006 01:31 AM
