Other Bike Chat Discuss other makes and models of bikes made by Honda, or competing brands.
Bike ran fine when parked now wont start?
Old Jul 28, 2011 | 03:28 PM
jdthompson0706's Avatar
Question Bike ran fine when parked now wont start?
ok so i have a '75 honda cb200t and i got it running and road it for a lil while then parked it for the night next day went down to start it up n it wont start. it is getting spark and gas and has compression...i took the carbs off and cleaned them and still nothing... any ideals?? i need all the advice i can get
Old Jul 28, 2011 | 03:37 PM
estate4life's Avatar
February 2012 ROTM
So when it parked over night, then do not start? Did starter turn over? Or just a click. Did you throttle too much gas? May be flooded with gas. Did you try running jump start?
Originally Posted by jdthompson0706
ok so i have a '74 honda cb200t and i got it running and road it for a lil while then parked it for the night next day went down to start it up n it wont start. it is getting spark and gas and has compression...i took the carbs off and cleaned them and still nothing... any ideals?? i need all the advice i can get
Old Jul 28, 2011 | 04:11 PM
yea it didnt run and i got it running it was a lil rough but it ran then i parked it now all it will do is turn over. i have tried pulling it once. what gear is best for push or pull starting??
Old Jul 28, 2011 | 04:29 PM
February 2012 ROTM
1st or 2nd
Gear should do...don't give it anymore gas...may be flooded/no air/no start...
Old Jul 28, 2011 | 04:31 PM
ok i will go try some more and see if it will start
Old Jul 28, 2011 | 04:55 PM
well we just went and pulled it like 5 times and it like backfired twice but never started
Old Jul 29, 2011 | 08:40 PM
kilgoretrout's Avatar
Administrator - Retired
Spray a bit of starting fluid into it and see if it takes off. If it does, you'll know you aren't getting fuel.
If it doesn't fire, I would try cleaning or replacing the plugs. They probably need it anyway. And bump starting is usually best done in second gear.
shok47
Mar 11, 2012 10:53 AM
jdthompson0706
Aug 3, 2011 08:02 AM
platnumbob
Jul 17, 2011 05:47 PM
Tripwire25
Jul 27, 2007 12:54 AM
