Rear Brake
Old Aug 6, 2006 | 02:27 PM
AZ1000rr's Avatar
Default Rear Brake
Okay, got a little feedback on who uses trail braking, now I wonder how many of us use the rear brake in corners....not the jam it on and high side technique, but feathering it to adjust your line?
Old Aug 6, 2006 | 02:42 PM
specialk's Avatar
Default RE: Rear Brake
i tap it if necessary to slow down while im still leaning.....i prefer to straighten up and break to prevent any unnecessary risks, but when im deep in a corner i definately give it a who's ur daddy
Old Aug 6, 2006 | 04:17 PM
BrianAZ's Avatar
I've used it to make the bike more compliable when getting ready to lean.
Old Aug 6, 2006 | 09:14 PM
929 FRB18's Avatar
i do, i often use it to adjust my line. i find it keeps the bike better behaved and gives a massive advantage when powering out of a corner. i use it and i recommend it
Old Aug 8, 2006 | 09:25 PM
FordFrenzy97's Avatar
Trail braking is a technique. You can also trail brake with the front brake. But yes I use both in corners sometimes.
Old Aug 10, 2006 | 10:54 AM
doggy69's Avatar
So you guys use the rear brake to increase oversteer.....
Old Aug 10, 2006 | 12:10 PM
rrasco's Avatar
i dont even like touching the rear brake, i have locked it up once at 50MPH (didnt highside...whoo..i had just broke my front brake lever) and i just dont even use it unless im sitting at a light. everytime i am riding and start to touch it the back feels like it starts to slide..and i dont like that feeling. so i just stay away from it all togethor. as for braking in a lean....i dropped the msf bike too many times doing that, lesson learned.
Old Aug 10, 2006 | 06:57 PM
snowboarding82's Avatar
The only time I'm going fast enough to have to brake in a turn would be when I'm out carvin up the 15-35mph corners. I don't use the brake I'll just let off the gas a little bit because when I'm running that area I usually keep it in 2nd or 3rd and the rpm's over 6k so the engine slows me down.
Mike
zellster
Aug 19, 2019 06:44 PM
gambit07
Mar 30, 2011 02:25 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
JJHUNSECKER
Sep 16, 2006 03:22 AM
mini bagels
Sep 4, 2006 04:31 PM
