Glove problems :(
Old Apr 26, 2007 | 07:12 PM
dwhite645's Avatar
Default RE: Glove problems :(
ORIGINAL: ebear
My fingers arent long enough (or so i THOUGHT) to fully disengage the clutch without lifting my palm slightly (I use 4 fingers) I never thought about that it was probably my hand position in relationship to the clutch or the clutch needs to be moved. I've only ridden a total of maybe an hour without gloves prior to getting them. soo.. hopefully wont take to long to fix the problem. Oh and yeah, I knew I should have been manually rolling the throttle back up.. So I guess it's a good thing.. Just wasn't used to it. I also just got boots.. they are so tall in the toe not as easy to shift I should probably adjust the shifter up some to.
Yeah, it'll take some getting used to. Just make sure to always wear your gear...and for the msf course too.
You may want to adjust the clutch, as you said, by loosening the pinch bolts and rotating it around on the clip on until you find a good spot. You can also adjust the distance of the clutch lever to the bar (depending on model) with the numberedwheel adjuster.
adjust the shift lever too...usually done with a threaded rod as the linkage so it moves the lever up or down.
Everything's adjustable on these bikes, which is nice.
Old Apr 26, 2007 | 09:10 PM
ebear's Avatar
ORIGINAL: dwhite645
ORIGINAL: ebear
I know I just havent done it yet. Yeah really need to move the shifter up. I just drove around my neighborhood right now. I didnt stall or get close or have my palm stick. Just adjusted my hand position. And yeah I got boots/jacket/helmet/gloves and I've always been wearing them since I got them.
Old Apr 26, 2007 | 09:19 PM
CBRCRF's Avatar
I broke mine in while driving my car.Same with the helmet.
Old Apr 26, 2007 | 09:23 PM
mkhaynesaz's Avatar
^^^ wait you drove your cage with your helemt and gloves on ! that is great !!! i would have loved to seen that while on my bike !!! .. that is great !!! i needed that i haven't laugh that hard all day
Old Apr 26, 2007 | 11:43 PM
hondadriver4life's Avatar
ORIGINAL: Analog
Doesn't have to be a bat, just anything smooth and roundthat wont tear up the leather.
dude youre such a gutter brain hahahahahahahaha
coldflood
Riding Gear
Aug 28, 2011 11:32 AM
Tremar
Riding Gear
20
Aug 24, 2011 10:59 PM
bigboi18184
Riding Gear
Nov 25, 2010 01:31 AM
boats203steveb
Riding Gear
Jun 28, 2007 08:54 PM
c0ldf1ame
Feb 28, 2007 12:56 PM
