06 600 rr won’t start
Old Oct 15, 2017 | 07:12 PM
MOTAUG's Avatar
Default 06 600 rr won’t start
had to remove clutch cover to fix oil leak Now bike won’t start. Just clicks and oil light is on but it has oil.
Old Oct 19, 2017 | 04:57 PM
Hawkwind2016's Avatar
Oil light will stay on until the bike is running, it's an oil pressure light, so if it's not running there's no pressure.
If the bike was running fine before you started working on it, then it's probably something you've done/moved/unplugged.
If you just get a click when you press the start button, then it might be something as simple as a flat battery. I'd try recharging your battery or a jump start from another battery.
Old Oct 19, 2017 | 06:35 PM
MOTAUG's Avatar
Default Still no start
so replaced battery checked fuses. No start.
Starter solenoid clicking. No start. Any ideas?
Old Oct 19, 2017 | 06:54 PM
74demon's Avatar
Is the starter motor turning?
Did you replace the cover?
Old Oct 19, 2017 | 07:43 PM
MOTAUG's Avatar
Yes everything is in place back together. No start just relay click.
Old Oct 20, 2017 | 07:11 AM
So starter motor is not turning the engine over, correct?
Might be worth reading through this thread of mine :-
https://cbrforum.com/forum/general-t...o-brah-155966/
Hope it helps, keep us posted.
Old Oct 20, 2017 | 09:18 AM
74demon's Avatar
Does the engine turn manually?
CBR-J
Aug 16, 2017 09:19 PM
Jordon Bent
Jan 22, 2014 05:48 AM
pskillman
May 1, 2010 06:45 PM
Slim@SBF
Dec 9, 2007 08:53 AM
cbr714
Jun 10, 2007 07:55 AM
