F4i lower temp fan switch & maybe other models
DEFENETLY doing this mod soon as i have a spare 35 bucks to spend, i spent $40!! on Engine Ice but that only knocked it down a few degrees, this will def help alot more.
i seem to have my 2002 wired up on a switch the same way..fan operates both manually and automaticly buttt
which direction does your fan go? blowing out towards the front or sucking in towards the engine? mine it blowing out, but i want to cahnge that.
so fromt the factory all the fans are blowing out? I wouild think drawing hot engine air and passing throught the radiator would only rise temps, not cool them.
wouldnt it make more sense if outside air passed through radi first? plus it would be the direction of air trabel if you were moving too.
I am new to CBR and I just wanted to truely thank Backroad and 914's for their great instructions.
COMPLETE THE MOD AND IT WORKS GREAT.
I have a 2000 CBR F4i which i just bought 4 weeks ago. The fan does not come on until 240 and off @ 238. So, the engine died due to the high heat. This fixed my problem.
1. I got my lower temp switch from Auto Zone and it fits perfectly. The coolant switch location is on the left hand side of the radiator. Took of the old switch and put the old O ring on the new switch and screwed in.
2. Two wire from the new switch, Hook one wire to top of radiator for ground, hook the other wire to the original plug that was plugged onto the old switch (going to the fan).
NOW TO INSTALL THE MANUAL SWITCH.
I just want to clarify to those that are new here, the original plug/wire that is going to the fan is also a negative/ground. So, all you're really doing is to connect the ground to the manual switch and then to that original plug/wire going to the fan. So when you turn the switch on, it gets grounded and the fan turns on. I assume the positive is always active to the fan motor.
3. Now, connect a wire (ground) to the top of radiator going to the manual switch.
4. Connect a second wire to the original plug/wire to the fan. NOTE...if you want the fan to come on BOTH automatically and manually, DO NOT cut the wire completely when doing the connection. Only splice the wire to get to the copper, then connect your new wire here. Run that new wire to your manual switch.
1ST TEST...The fan comes ON @ 209 and OFF @ 205. So, looks like it's working exactly as it should. The fan works perfect both automatically and manually. I can turn on the fan anytime with the switch and it will also turn on automatically by the sensor when temp hits 209.
When I bought my 97 F3 a week ago, the guy told me he installed the manual switch for the fan. It worked for the week, but today I took it out for a quick ride and upon return I tried to turn on the fan, and it didn't work. I'm not sure what the problem could be!
I posted a similar how-to mod with pics on here last year. Mine will turn on one or both fans but will still turn off when the key is off in case someone forgets to turn the switch off. The fans will also turn on automatically if the engine temp rises to 217*F (fan #1) or 223*F (fans #1 and #2).
Was the key in the ON position? If he wired it correctly it should only work with the key turned on.
