F4i lower temp fan switch & maybe other models
#41
What did the manual say to do to test the fan?
#42
The theory of operation should be the same. You just need to find which is the ground wire that goes to the fan relay and add another ground wire with a switch going to the same spot on the relay socket. I believe the '06 has just one fan, so you wouldn't need the 3-way switch in the how-to. Just a simple on/off.
1.) Disconnect connector from fan motor switch
2.) Ground connector to body with jumper wire.
3.) Turn Ignition switch on, check fan motor.
it didn't start...
#43
Maybe I'm missing something. When you unplug the connector there's nothing at all going to the fan. When you ground it then there's only the ground side going to it. It still needs 12V power to run.
#44
Idk, I'm taking in to get new tires and all the fluids changed out probably next month...but I'm hoping I don't have to ask the mechanics to take a look at it.
#45
The way you described it the jumper wire is just a ground wire. You still need to supply +12V power from somewhere to the fan to test it.
#46
Thanks RoadiJeff, Found the relay on the '06 It is actually found behind the front left faring next to the fuse box.. I will post pictures here in a few.. i will also add to your write up for the 1000RR
Pictures as promised.
The box in the middle to the left of the fuse box is the one you need to splice into.
Put the switch wire into the blue/grey wire seen below (my wire going in is green)
Finally the finished product
Thanks again to all the forums and people that helped with this =)
#47
#48
Advance Auto Parts no longer lists the part. Autozone still shows the part on their website with the same part # SW524 that was in the original post. If you don't have a local Autozone store you can order from them online or check other parts stores for a fan switch or fan sensor for a 1983 Nissan Pulsar 1.6L engine. Note that some switches may not have the wire pigtails so you can't splice them. Be sure to get a switch like the one pictured on the link below that has the 2 wires and a connector.
Here's a link to the part on Autozone's website.....
Clicky
Clicky
#50
