Valve Shims
Old May 2, 2008 | 03:22 PM
axsys's Avatar
Default Valve Shims
hey guys, im getting ready to check my valves on my 02 F4i, and was wondering where the best place to get an assortment of shims would be. are there shims that are specifically for the F4i, or just for Honda bikes in general? thanks!
Old May 2, 2008 | 10:33 PM
02blade's Avatar
Default RE: Valve Shims
I just got done doing mine on my 954, I went to the honda dealer and there about 8 bucks each, dont know if there universal or just general for honda's, mine looked like the size of an eraser and were round. hope that helps.
Old May 3, 2008 | 01:18 AM
SurfnSCal's Avatar
You can go to just about any dealer. I think you are running 7.5mm shims. Each manufacture makes shims those size, and also aftermarket shims. I think though the thing you want to look for are shims that look like they are harden. There are two types of material I think they make shims in. Sintered like sintered brake pads, and hardened metal ones. I was never sure which was suppose to work for what bikes, but if you get the OEM honda ones you can't go wrong. But i think that hot cams, and the other aftermarket ones use sintered type shims.
Old May 4, 2008 | 01:29 PM
KidCr3nshaw's Avatar
If you're going to be doing this yourself in the future, you can get shim kits for a little change.
Old May 4, 2008 | 05:40 PM
axsys's Avatar
KidCr3nshaw, can you recommend somewhere online to get a kit, or should my local dealer have one?
Conrice
Jul 18, 2012 10:13 AM
swaskowiak
F2 Tech
Jun 3, 2012 07:59 AM
mark1200
Mar 2, 2011 01:12 PM
oldschoolsdime92
Oct 31, 2008 11:00 PM
jalate compa
Nov 14, 2007 08:55 PM
