Two clicks in cable/lever when pulling in clutch
Old Sep 17, 2016 | 04:07 AM
RP Rides's Avatar
Default Two clicks in cable/lever when pulling in clutch
So when I pull the clutch lever in, there's two little clicks that end up happening - first somewhere around 1/3 of the way in, and the other somewhere around 2/3 of the way in. It seems like it's coming from the cable/lever area, but I haven't gotten the chance to explore or dig deeper.
Has anyone else experienced this before? Could it just be that the cable is sort of binding on something and needs to be lubed up?
Old Sep 17, 2016 | 07:32 AM
Jaybird180's Avatar
1-Make sure the cable isn't frayed. Lubricate the cable.
2-Pull the lever and take a look at the bolt that holds the lever in place, it may be the wrong fastener. It should be a stud with just a thread at the end and not threaded all the way. There's a nut underneath. Remove it first, then undo the stud/bolt with a flathead. Also check for excessive play in the stud holder.
Old Sep 17, 2016 | 07:33 AM
Jaybird180's Avatar
Welcome to motorcycling.
There's riding and there's wrenching. Get to love both.
circus
May 3, 2010 08:40 PM
keithacole
Jul 16, 2007 09:38 AM
chrisf
Sep 26, 2006 12:01 AM
crucialfate
Mar 14, 2006 11:11 AM
