clutch lever and cable
Old Mar 3, 2006 | 11:59 AM
crucialfate's Avatar
Default clutch lever and cable
ok, so last night i was cruising around and I heard something metal fall, i stopped and looked, saw nothing. Shortlyafter, my bike acted like it wasn't catching right (like i was letting off the clutch real slow). Then my clutch lever was not releasing all the way and i had to push it out. After doing this at a stop light, it went completely into freeplay. NO CLUTCH and STUCK IN FIRST!!!! [sm=headbang.gif] The lever is broken where thre "tensioner" is and the cable is snapped back into the wire casing. Now my bike is sitting in my driveway under a tarp because its about to rain. I have checked ebay and have found nothing, does anyone know where i can find what i need?
[IMG]local://upfiles/4788/DB228FBB43C04FCC966B2C1DCC7F0524.jpg[/IMG]
[IMG]local://upfiles/4788/0074BDE52CE34151AEF54E9E0BA541C6.jpg[/IMG]
[IMG]local://upfiles/4788/72BC07284F9041E3B30BA3F1EA6E88EE.jpg[/IMG]
Old Mar 3, 2006 | 12:10 PM
Default RE: clutch lever and cable
for an 87 cbr 1000f
Old Mar 3, 2006 | 01:35 PM
Texas CBR1000F's Avatar
For all CBR1000F parts on ebay:
http://search-desc.ebay.com/CBR1000F...1QQxpufuZxQ5A1
Here are some levers:
http://cgi.ebay.com/ebaymotors/CBR10...17527317QQrdZ1
Here is a master cylinder kit:
http://cgi.ebay.com/ebaymotors/CLUTC...74126956QQrdZ1
Your local dealer should have the parts that you need.
Old Mar 3, 2006 | 03:24 PM
slowpoke's Avatar
There is no cable, all 1000F's use an hydraulic clutch. From your pictures I can't tell if the pivot point is broken on the lever or if the housing on the hydraulic cylinder is broken or both.
Old Mar 3, 2006 | 08:48 PM
Trips's Avatar
The pic below is of a later model CBR , but the way it works is basically the same.
There is a cylindrical bush, that pushes on a rod that pushes on the matercylinder cup. The rod slides in a housing.
So I would say that the rod, housing & bush are what you heard hitting the ground. But its all guesswork as I dont have any manuals for that year.
Old Mar 6, 2006 | 08:58 PM
any idea on how much replacing all that would cost?
Old Mar 7, 2006 | 06:39 AM
Trips's Avatar
Dunno,
I am from Australia. Just look up ya local wreckers. Or go cruising ya local carpark with a toolkit. lol :P
Old Mar 8, 2006 | 11:52 PM
ok, so now i that i know that i dont have a cable and it is hydralic, things get complicated. if anyone has a clutch master cylinder (casing box and internals) i would be willing to buy it. for a reasonable price
Old Mar 8, 2006 | 11:58 PM
and does anyone know if they are interchangable from other hurricanes such as the 600 or other year models.
Old Mar 9, 2006 | 07:44 AM
Stuyvo's Avatar
Mate, just replaced my clutch blade which cost $15 australian. The piston snd rubber bush was only another $12. my old blade simply wore out after 20 years as I suspect yours has. Get your hands on a Haynes manual, worth the $50.
