trun signal problem
Old Sep 21, 2007 | 11:36 AM
118367s's Avatar
Default trun signal problem
my trun signals wont work i even changed the fuses tail light works and the run off the same fuse i dont know what going on can some onbe help i hate sticking my leg out
Old Sep 25, 2007 | 11:29 PM
118367s's Avatar
Default RE: trun signal problem
nobody
Old Sep 26, 2007 | 01:16 AM
pacemaker's Avatar
Have you checked to see that you don't have a blown bulb. Maybe a faulty (as in cactus) Turn signal relay
Old Sep 26, 2007 | 08:08 AM
tomc1965's Avatar
What bike do you have? Is it the 96 CBR900rr you list in your profile?
Have you changed out the bulbs recently to LED or are they the stock bulbs? LED bulbs need a resistor inline to function in a bike that came without LED bulbs.
If they are stock bulbs and just stopped working check that your bulbs and sockets are not corroded and clean or replace as necessary. Could also bea bad relay. Could be you need to clean the contacts on the turn signal switch (on the handlebar).
Old Oct 6, 2007 | 12:18 PM
SpiritBreaker's Avatar
I have the same problem but different situation. Could it be the relay?
Let me know !
https://cbrforum.com/m_402712/tm.htm
utter05
Jan 22, 2009 01:10 PM
Stugots
May 1, 2008 03:51 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Brandon77
Jan 8, 2007 04:36 PM
Rajj
Mar 16, 2006 02:27 PM
