will not start
Old Sep 28, 2007 | 11:17 PM
tdiv135's Avatar
Default will not start
ok i have a 02 954 it turns over but will not start the fuel pump does not prime and i get no spark any ideas.
Old Sep 28, 2007 | 11:21 PM
sixhundredrr's Avatar
Default RE: will not start
Electrical problem. Check fuses.
Old Sep 28, 2007 | 11:23 PM
tdiv135's Avatar
i did all fuses are good
Old Sep 29, 2007 | 12:50 AM
knightslugger's Avatar
Chek your Relays and BAS. check your engine run switch position and your safety switches.
Old Oct 6, 2007 | 12:22 PM
SpiritBreaker's Avatar
ORIGINAL: knightslugger
Which Relays and how do you tell if they are bad?
By the way its "BAS"?
https://cbrforum.com/m_402712/tm.htm
Old Oct 6, 2007 | 12:56 PM
HAVOC's Avatar
^ B.A.S is your bank angle sensor.. or "tip" over sensor .. it will keep your fuel pump from priming and you cant start your bike but you will be able to still crank it.
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
