sudden death?
Old Apr 24, 2010 | 10:18 AM
JoLlY rAnChEr's Avatar
Default sudden death?
I just got ahold of a 2000 cbr600f4 and i was told that the only things she needed was 1 fuse 2 oil change 3 new tires....well i fixed all these problems and got to take it out yesterday for my frist ride ever....made it around a few blocks ab 20min worth of riding...and i stalled her trying to go fron N to 1st and all the lights went out...checked the wireing...all fuses good...so i replaced em ne ways...checked ground..replaced ground...still no power? ne thoughts?
Old Apr 24, 2010 | 10:25 AM
Kuroshio's Avatar
You check the main fuse? The 30a fuse. Check the ignition switch too. Could be a bad connection there
Old Apr 24, 2010 | 10:58 AM
i checked the main fuse...and it was good so i replaced it just to make shure...but i didnt check the ingition switch
Old Apr 24, 2010 | 11:24 AM
dyracuse's Avatar
Battery connection can do it since they have to run their power from off the battery even while running. Mine I didn't snug mine down good enough and it did the same thing almost, sputtered and stalled leaving a gas station.
Old Apr 24, 2010 | 11:51 AM
battery checked...bolts tightened and all cleaned...power to main fuse box goin to harness..but reading no power to other fuse box?...useing probe with dummy light...checked the tops of fuses while key was on...
Old Apr 25, 2010 | 08:05 AM
Power generally goes from the battery to the Starter Relay as well as to the 30A fuse (30A on a F3, others may be diffferent). Leaving the fuse, it goes to the Ignition Switch, and then to the Fuse Box. If your main fuse is good, then the Ignition Switch is the next place to look.
Old Apr 25, 2010 | 10:43 AM
rgr..ill check the ingition switch asap...get back to yall toniight
Old Apr 25, 2010 | 08:21 PM
JEFF4i99's Avatar
Definitely check the ignition assembly. Mine would suddenly die because the killswitch wire was shorting.
Old Apr 26, 2010 | 08:52 PM
problem solved...ingition was not connected..took her out for a nice joy ride..hooked for life now!
superlund
Jan 3, 2011 11:08 PM
toyvette81
Sep 28, 2007 12:50 PM
electronspeeder
May 1, 2007 02:28 PM
dc_220
Nov 28, 2005 12:26 AM
