Sticky throttle
Old Dec 10, 2006 | 02:26 PM
Bike Ryder's Avatar
Default Sticky throttle
Hey guys i just but a 96 f3 and am having alittle trouble with the thottle. When i bought it the right handle bar was slightly been cuz of a drop and we thoguht thats whyt he trhottle stuckle, but appearently its not. It takes mroe effort then it should to tiwst it towards me and then it doesnt twist back on its own u have to twist it back with ur hand. does anybody have any diea what to do, is it justa wd40 kinda htink or is there something bigger?
Old Dec 10, 2006 | 03:42 PM
CrF450r420's Avatar
Default RE: Sticky throttle
It could be a few parts. You need to slowly cut things out of the loop. Start by taking the throttle appart and just using the cables directly. If it returns then you need to look at the throttle assemly on the bar. If it doesn't. Disconnect the cables and operate the throttle directly. If it still doesn't return then your spring is dead/gone or something is scrapping. Sounds more like something is bent and/or scraping since it is hard both ways. If you find out it's the cable you can try to lube them up, but it would probably be safer to replace them.
Old Dec 10, 2006 | 10:04 PM
pacemaker's Avatar
Check the throttle cable adjustment on the bar 1st
Old Dec 10, 2006 | 10:44 PM
zerochickenstrips's Avatar
Yes the easiest thing to check is throttle freeplay. There should be about 1-2 mm of throttle turn before the carb butterflies actually begin to open. A tight throttle cable will be hard to turn and won't return correctly.
Old Dec 11, 2006 | 11:03 AM
GEARHEAD69's Avatar
I had a friend that put after market grips and bar ends on his bike a caused a similar effect!! Check the grips and bar ends!!
Old Dec 11, 2006 | 07:02 PM
bushmasterAR15's Avatar
cable is mucky, get a new one. Could try wd-40 but probably wont work well.
Mwall
Aug 28, 2008 04:13 PM
toeknee1986
May 24, 2008 09:52 PM
cbrvroom
Apr 29, 2008 04:45 PM
kpshogry
Dec 4, 2007 09:30 AM
Cutlassjim
Jun 19, 2006 10:35 PM
