slack in tranny
Old Sep 1, 2006 | 01:23 AM
Junior's Avatar
Default slack in tranny
when i get on it its all good when i let off and get back on it, it slams forward like there is too much space between the drive gears. is there any way to tighten that up?
Old Sep 1, 2006 | 01:24 AM
Junior's Avatar
Default RE: slack in tranny
it is a 90 cbr 600
Old Sep 1, 2006 | 03:27 AM
BlindLOKI's Avatar
could it maybe be your chain slack? It does that when your chain is loose, or even in spec... it takes a bit to catch up cause when you get on it its on full tight up top, then you let off, full tight on bottom, get on it its gotta pic up all that slack so youll get a split second of lash then pffft, your gone.... good luck
Old Sep 1, 2006 | 04:05 AM
rippn's Avatar
LOKI... Good call. Seems to make alot of dif. Proper lubed chain, to top it off. Clean and free, Ripp'n
Old Sep 1, 2006 | 06:06 AM
mikequinn's Avatar
you'll get used to it in time , & you'll change your riding style to suit.....
Old Sep 1, 2006 | 05:19 PM
Junior's Avatar
i dont think my riding style has anything to do with it ive rode many bikes but none with quite as much freeplay. the chain makes sense but its fairly new and tight. im almost positive it is in the tranny. is it a cbr thing that im not aware of?
Old Sep 2, 2006 | 06:21 AM
chainstretcher's Avatar
Admin Emeritus & MVN
A '90 CBR600 ... hmmm, I've not noticed the CBR's having more lash than other bikes. If your chain is adjusted correctly then it could be that you got some wear in the tranny. How many miles on your bike?
Old Sep 3, 2006 | 05:33 PM
Junior's Avatar
almost 8000 on the odometer, and the chain is adjusted and lubed properly.
Old Sep 3, 2006 | 06:00 PM
That's not a lot of miles to have a tranny related issue. Not saying it couldn't happen but I imagine the bike would have to be ridden really hard to have such an issue.
How about this ... with the engine off put the bike in first and roll it forward until it stops then roll it backwards until it stops. What is this distance? If it's more than 4 inches then you've got something going on in the tranny. Otherwise I'd be inclined to check the clutch springs and pads.
Err
Sep 28, 2006 03:07 AM
phsycleRR
Sep 2, 2006 08:44 AM
Slow900RR
Sep 2, 2006 01:16 AM
raredogg
Aug 28, 2006 09:30 PM
ninetyfivehp
Jul 29, 2006 10:32 PM
