Shock Replacement
Old Feb 7, 2005 | 10:17 PM
PiMpBlueF2's Avatar
Default Shock Replacement
whats up guyyys n girls, possibly? i don't really know.....anyways......i got a 93 F2 and just got a new shock for it, i understand to remove the bolts for the shock, but is there anything i need to kno before i replace it?? like do i need two people, one to lift up on the subframe to release the tension of the shock?? or can i just do it by myself without help?? please respond....thanks
Old Feb 7, 2005 | 11:07 PM
sirlimpzalot's Avatar
Default RE: Shock Replacement
Just make sure that there is NO WEIGHT on the rear end, since the shock is what is holding your bikes rear end up. If you release the bolts with a load on the shock, it will fall. I have wedged a block of wood in between the subframe and the swingarm as a support; or if you can hang the subframe from the rafters and have it suspended
RudyGT
Dec 20, 2013 01:38 PM
PILGRIMSUPPORTER
Jul 20, 2012 04:26 AM
bigape
May 24, 2008 01:33 PM
specializedfuji
Apr 6, 2008 04:38 PM
Ghost1Rider
Apr 10, 2007 08:20 AM
