shift rod snapped.
Old Mar 12, 2006 | 10:31 AM
mysteereusone's Avatar
Default shift rod snapped.
Today sucked, the first good day of riding and about an hour into a ride I pull out onto a four lane divided highway and go for second gear and nothing. I look down and my shift lever is just dangling. I was able to coast to the shoulder were I could manually jam it into third so I could make it home. Thanks to the sprocket conversion I could take off in third OK and would just have to hold the clutch in when I stop. My question is can I just replace the tie rod bolt or would I have to replace the whole mechanism (the shift lever, linkage rod, and the arm that bolts onto the transmission shaft)? Any ideas?
Old Mar 12, 2006 | 04:19 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: shift rod snapped.
Was it just the rod that snapped -- ya know between the heim joints and jam nuts? If so then you can order just that piece but it'll prolly take the shop a week to get it in.
Old Mar 12, 2006 | 04:26 PM
Yeah it was just the rod itself. I went to the local honda shop and ordered one for 5 bucks. Should be in, in a couple days. Do you just screw the both ends back in or will I have to take everything off put it together and then put it back on as one piece?
Old Mar 12, 2006 | 04:36 PM
Ya, just screw both ends in at the same time -- keep running it in until it's adjusted like you like it then tighten the jam nuts.
Old Mar 12, 2006 | 05:55 PM
great, thanks for the help.
Aussie Johnno
Jul 25, 2018 02:42 PM
pocfoo
May 18, 2011 04:01 PM
Juliet
Oct 10, 2008 07:11 AM
Heaton830
Jun 24, 2007 02:33 PM
